Speed Test not working
Neondaze
I have just tried to use the PlusNet speed test. Although I can access the speed test page, clicking the button 'Start Speed Test' results in no action. The button does not depress and I get no pop up. I ran the speed test yesterday without any problems. I have made no changes to my set up since the lasr successful use of Speed Test.
Is anyone aware of an issue with Speed Test at the moment or should I raise a ticket.
It can be a bit temperamental at times.
Are you sure you don't have a pop-up blocker stopping the page appearing. Even though it may have worked yesterday something may have changed to cause this.
Try ADSLguide speedtest instead.
Neondaze
Thanks for the reply.
As far as I was aware the pop-up blocker was disabled for this site. But on your suggestion I checked and low and behold pop-ups were blocked. I recently had an update from Zone Alarm which may have caused this, although I was sure that was last week.
Anyway, speed test working now, so thanks again.
Kevin
