Speed Question ?
AndyMan
Speed Question ?
I have run a few BT speed tests (results below) and also each time I ran plusnets speed test for comprison. I also ran other speed tests around the same time and all roughly agreed with the plusnet tests results.
After reading James' sticky above , especially the part about the BT speed test NOT going through Plusnets servers, would I be right in thinking my speed issue is not BT related but down to Plusnets servers ?
BTW I have tickets raised for this , am interested in others opinions.
Plusnet Speedtest
02-02-2007 07:40:18 2142.5
02-02-2007 07:36:25 1599.8
BT
2/2/2007 = 07:37
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 4500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 5632 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 4162 kbps
Plusnet Speedtest
02-02-2007 17:57:14 1379.2
BT
2/2/2007 = 18:00
Actual IP throughput achieved during the test was - 3435 kbps
Plusnet Speedtest
03-02-2007 07:16:22 1825.3
03-02-2007 07:12:26 1604.5
BT
3/2/2007 = 07:15
Actual IP throughput achieved during the test was - 3910 kbps
BT SPEEDTESTER
4/2/2007 = 8:29
DSL connection rate: 448 kbps(UP-STREAM) 6560 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 4086 kbps
5/2/2007 = 07:17
IP profile for your line is - 5500 kbps
Actual IP throughput achieved during the test was - 4709 kbps
5/2/2007 = 07:55
IP profile for your line is - 6000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 7360 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 4791 kbps
THROUGH PN'S SERVERS
05-02-2007 07:59:01 1847
04-02-2007 08:30:10 2021.1
04-02-2007 08:22:14 1953.4
James
Speed Question ?
Hi Andy,
Firstly, I need to amend my sticky as phase 1 of the new BT Speedtest, doesn't actually test against the exchange. Also, the PlusNet speed checker is rather shoddy - we have a new one coming soon. Try this one instead:
http://www.speedtest.bbmax.co.uk/
AndyMan
Speed Question ?
I did use that one too and it roughly agreed with the plusnet one ...
