Speed Question
thehatman
Speed Question
On BT line MaxDSL is this normal: A stable rate (meansurement from the thing on this site) of 8000, but actual speeds (again measured on this site) of between 3 and 6 MB.
Never 7 or 8, and usually 3-5, only occasionally 6.
Will it improve, what I can or PN do if anything to get the best out of this?
Does it really make any difference changing your wiring? And can I tell if this is worthwhile by measuring line noise stats - where do I do that?
Thanks. Smiley
JJ
Speed Question
BT have not upgraded their backhaul from the exchange so ‘contention’ on MaxDSL is far more obvious.
Expect speeds to be 1-3.5Mb at peak times and 3-6.5Mb at other times.
Personally I have had the whole range at peak times 500k to 6.5Mb. Unfortunately this is how it will be for all of us on 100% BT exchanges.
Until BT do something about the backhaul capacity expect things to get worse and that’s for all ISP’s not just PN. Those fortunate enough to be on LLU enabled exchanges might be better off until such time as their backhaul is overloaded.
thehatman
Speed Question
Thank you. That is very helpful. Smiley
Where can I see statts for my line noise and so on that I see others quoting?
Oh, what is the exact definition of "backhaul" ?
JJ
Speed Question
Things should improve when BT get round to replacing their existing DSLAMS and things with the new multi-service access nodes (MSANS) which at least can handle 40Gbps throughputs.
I think they have just started (as it's BT about to start) on the Cardiff exchanges.
Anyone know for certain ?
JohnH
JJ
Speed Question
Basically its the connection between your local exchange and BT's network BEFORE it gets to PN.
This link tells you how it all works.
http://www.btplc.com/Thegroup/Networkstory/NetworkStory.html
If you let us know what modem you have someone should be able to tell you how to get to the noise figures etc.
JohnH
Slick
Speed Question
as for speeds, with the amount of traffic on the net then that wont help
im on wireless belkin router and synced @8000 and i ftp @785 kbps every time
but dl is all due to the site bandwidth
JJ
Speed Question
woteva,
have you read http://portal.plus.net/central/forums/viewtopic.php?t=43016
it might (and I mean might) be worth experimenting with your own modem.
JohnH
