Speed Increase?
Speed Increase?
I was supposedly upgraded to DslMax yesterday, my router is showing
Up Stream 448 (Kbps.)
Down Stream 7616 (Kbps.)
But on speed tests i get is as follows, i was on a 2mb line by the way :?
Is there anyhting wrong?, as i was expecting a big improvement today :?
Mr S Robinson
Liam
Speed Increase?
It can take a couple of weeks for your line to stabalise to the higher speeds available with Max.
I would recommend reading the following guide which explains the process in a bit more detail :
http://www.plus.net/support/broadband/products/getready.shtml?link=suptop5_general5
Speed Increase?
Ok thx for the speedy reply
James
Speed Increase?
Hiya,
Whilst the advice that Liam has offered you is sound, I have also changed your profile at our end, which will hopefully result in your seeing faster speeds.
Alan_Chantler
Speed Increase?
Hiya,
That's interesting! I was upgraded to MaxDSL ten days ago. I haveseen a speed of 956Kbps since but only once. Today I get this:
Any thoughts?
I am NOT a happy bunny!
Alan Chantler
Speed Increase?
bahahhah
sorry Smiley
but welcome to the angry plus net customers club
kjaerligkatt
Re: Speed Increase?
Any thoughts?
Do you have any line stats info you can provide?
Neil
Speed Increase?
Hiya,
Many Thanks
Alan_Chantler
Re: Speed Increase?
Any thoughts?
Neil
My ADSL Modem/Router gives this lot. ANy use?
Downstream Upstream
SNR Margin 6.1 11.0 dB
Line Attenuation 56.9 31.0 dB
Errored Seconds 20173 1917
Loss of Signal 5 5
Loss of Frame 0 0
CRC Errors 33948 437
Data Rate 1856 448 kbps
Latency INTERLEAVED INTERLEAVED
Alan C
kjaerligkatt
Speed Increase?
It looks like you're some distance from your exchange with those stats - you're sync rate may well be the best you're going to get, and the best throughput you could expect is ~1.5Mbps.
Try the speed test at quieter times (early morning) to see if you get closer to the max.throughput you can expect. If you get better results off peak, it could well be that your lower speeds are down to contention.
Neil
