Somethings hammering my connection 100mb+ so far
aeroalfie
I upgraded to PAYG this morning and ever since something has been hammering my connection it’s used 170mb of data so far todayHuh
Is this some kind of virus or what? Something at PN end?
Seems to be 100’s of incoming packts from various IP’s sent to various destination ports?
any programs i should d/l to check this out?
any help much aprechiated, thanks
Fixes: 57
What firewall are you using.
It could be that the IP was being used by someone who has been using P2P recently, although 170MB is quite a lot for bounced incoming traffic. This is one problem, no matter if your network is protected, any traffic to your external IP for whatever reason, accepted, bounced or retransmitted packets, is counted towards usage.
aeroalfie
hi hotlane i use Kerio firewall - still no let up?
James
It's not a wireless router by any chance?
Fixes: 8
If it's still going on I suggest you report this to the Plusnet abuse team.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
