So what T&Cs am i on now for plus?
Am i on 5GB 8am-midnight peak
OR
3GB 4pm-midnight peak?
I dont know, so which one? Got the newsletter but as usual i dont recall it saying an implementation date.
IIRC from the updates you will be switched on to the new product and times when you're next billed.
OK cool, looks like im on the new one now then since the bill came through 2 days ago.
cheers.
Fixes: 8
Not yet you aren't - it's the first billing date after 30th March.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
In that case you won't be on the new limits. The changes occur on your first billing date after the end of March. So you'll have to wait until the end of April.
Users should be able to clearly see the difference when they check they VMBU page as it will be changed to the new format when the account is changed.
Sweet, got all this month on old management then, bill doesnt come through untl the 27th.
Cheers for that, thats cheered me up a bit.
Fixes: 8
Lucky you. You can sit there watching all the disasters through the month, smug in the knowledge that by the time they get to you the problems will hopefully be sorted out. Wink
