Slow ping first hop to PlusNet
Dizzley
Anyone else seeing this in peak time?
tracert www.google.com
Tracing route to www.l.google.com [64.233.183.104]
over a maximum of 30 hops:
1 1 ms 2 ms 6 ms fudgenet [192.168.7.1]
2 149 ms 151 ms 156 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 18 ms 23 ms 18 ms ge0-0-0-103.ptn-gw2.plus.net [84.92.3.18]
4 27 ms 26 ms 20 ms ge-4-1.metro2-londencyh00. (etc...)
5 19 ms 18 ms 22 ms 195.50.116.70
6 25 ms 20 ms 18 ms 72.14.238.244
7 30 ms 28 ms 32 ms 216.239.43.91
8 36 ms 37 ms 36 ms 72.14.232.141
9 37 ms 30 ms 35 ms 72.14.233.79
10 35 ms 41 ms 37 ms 216.239.43.30
11 33 ms 32 ms 38 ms 64.233.183.104
Trace complete.
It was the same yesterday. Lots of pages won't load in the browser. It's only happened since Maxxing. Actually getting a reported 2.3Mbps just now but it took 30 seconds to draw the speed test results page.
It did get better yesterday evening, but I too am seeing the sluggish ping on the first hop, with an average of 120ms versus 15-25ms for all the other hops.
My first hop is subtly different at lo0-plusnet.ptn-ag2.plus.net
Dizzley
I just logged ticket 19347471.
Let's see if there's a response.
passer
Same as asimons.
I'm on ptn-ag2, with first hop around 100 ms and subsequents around 20-30 ms.
Also, portal navigation is particularly turgid at the moment.
I had no problems last night on ptn-ag2.
Same here.
Besides my router being pathetic in the art of a quick first ping the first hop is somehow worrying.
C:\Documents and Settings\Tom>tracert www.l.google.com
Tracing route to www.l.google.com [64.233.183.103]
1 9 ms 1 ms 1 ms 192.168.1.1
2 164 ms 158 ms 157 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 22 ms 20 ms 20 ms ge0-0-0-504.pte-gw1.plus.net [84.92.4.89]
4 23 ms 22 ms 21 ms 195.50.117.169
5 21 ms 22 ms 21 ms ae-0-51.gar1.London1.Level3.net [4.68.116.11]
6 28 ms 31 ms 28 ms so-6-0.metro2-londencyh00.London1.Level3.net [21
2.113.3.26]
7 52 ms 52 ms 54 ms 195.50.116.70
8 58 ms 57 ms 56 ms 72.14.238.244
9 68 ms 68 ms 68 ms 216.239.43.91
10 67 ms 67 ms 67 ms 72.14.232.141
11 90 ms 75 ms 81 ms 72.14.233.77
12 83 ms 71 ms 75 ms 216.239.43.34
13 75 ms 74 ms 76 ms 64.233.183.103
Trace complete.
well this is what i just dug up - something off is certainly happening... (ignore hop1 as this is my firewall)
1 <1 ms <1 ms <1 ms ipcop.localdomain [192.168.0.1]
2 94 ms 111 ms 111 ms lo0-plusnet.thn-ag1.plus.net [195.166.128.80]
3 37 ms 31 ms 31 ms gi0-2-0-303.pte-gw2.plus.net [84.92.3.178]
4 21 ms 31 ms 31 ms 195.50.117.169
5 22 ms 31 ms 31 ms ae-0-53.gar1.London1.Level3.net [4.68.116.75]
6 37 ms 30 ms 31 ms so-6-0.metro2-londencyh00.London1.Level3.net [212.113.3.26]
7 37 ms 47 ms 47 ms 195.50.116.70
8 54 ms 47 ms 47 ms 72.14.238.244
9 100 ms 63 ms 63 ms 216.239.43.91
10 70 ms 63 ms 79 ms 72.14.232.141
11 69 ms 63 ms 63 ms 72.14.233.77
12 70 ms 63 ms 63 ms 216.239.43.30
13 70 ms 79 ms 79 ms 64.233.183.104
Trace complete.
JonathanW
I've raised this through to our networks team, so that they can investigate it. Though in the short term the best advice is the old disconnect for a couple of minutes and then reconnect, as this should bounce you onto another gateway.
Hi John - really appreciate your input.
But I'm having a real problem with this plus net approach of recomending a restart to get onto a different gateway for many different issues. It seems I have been reading about this approach for months. This seems like a really half baked sticking plaster fix. Hang on - it seems like it because it is.
Why can plusnet not fix the gateways so that they ALL work at full performance?
What does this say about your attitude to those who don't visit the forums, and don't realise that this is what they must do to get a good connection? Do you expect them to continue to pay for a substandard service?
Why should I HAVE to work out what is a "good" gateway, and then restart my router to try to get onto it?
All ISP's are allowed to have things go wrong. What I really don't like is the consistant refusal to fix things properly, and to rely on these - frankly - unprofessional workarounds.
Jon thanks for the advice and just for your info i did follow it but...
Tracing route to www.l.google.com [64.233.183.99]
2 113 ms 111 ms 127 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
3 38 ms 31 ms 31 ms ge1-0-0-204.ptn-gw1.plus.net [84.92.3.105]
4 37 ms 31 ms 31 ms ge-4-1.metro2-londencyh00.London1.Level3.net [212.113.11.41]
5 54 ms 47 ms 63 ms 195.50.116.70
6 54 ms 62 ms 63 ms 72.14.238.244
7 68 ms 63 ms 63 ms 216.239.43.91
8 86 ms 63 ms 63 ms 72.14.232.141
9 53 ms 63 ms 63 ms 72.14.233.79
10 70 ms 63 ms 79 ms 216.239.43.30
11 69 ms 63 ms 63 ms 64.233.183.99
Trace complete.
different gateway but still a very high response from that 1st "checkpoint" of yours ...
Dizzley
Thanks Jon
However, I just hopped from ag1 to ag2 and improved to 95ms pings. This is the second evening running.
I'm cool about it though - a chance to nip to Tesco IRL. Wink
Jon,
We all have got slightly different gateways I think
smpclough> lo0-plusnet.thn-ag1.plus.net
tomspcs ( me ) > lo0-plusnet.pte-ag2.plus.net
brandon2 > ptn-ag2
asimons > lo0-plusnet.ptn-ag2.plus.net
disley > lo0-plusnet.ptn-ag1.plus.net
So far
PTN 1 & 2
PTE 2
THN 1
Appear to be affected. Something tells me that PTE 1 might also be affected Wink (unless I am barking up the wrong tree in which case forgive me)
Regards,
Dizzley
Guess what the common factor between user and PN gateways then...
BT network. Evil
BT network. Evil
now why would that be a surprise ...
and i know my connection isn't running flat out yet on maxdsl but can't get much done about it till end of 10 days (stupid BTw)
JonathanW
My recommendation to disconnect for a few minutes isn't intended to be a long term fix to the problem, more of a quick way to improve things whilst a real solution is worked on.
At the moment people are seeing latency on a couple of the gateways, but this isn't something that is going to be resolved straight away, as it will take investigation to determine what is causing it before we can resolve it fully.
Funny. This was reported yesterday evening
http://portal.plus.net/central/forums/viewtopic.php?t=42512&highlight=
Yet you are still in the "investigation" stage.
