Slow Speeds?
Slow Speeds?
Can anyone point me in the right direction?
Download and upload speeds have nearly halved and i don't know why!!
Latest test was 1027 down
router is still showing 2272 down and 288 up
tried rebooting but no change
Any ideas anyone?
Slow Speeds?
Search through the forum mate, the answers are there...its the maxdsl stability thats causing the problems....or should i say INstability :lol:
and if you think thats bad...take a look at This
During the morning I can download at around 6mb, afternoon onwards its down to almost 512k
Fixes: 8
Slow Speeds?
What speed do you get from the ADSLGuide speed tester?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Slow Speeds?
This is what i got from your link
Downstream: 937.11 Kbps (0.92 Mbps)
Upstream: 120.73 Kbps (0.12 Mbps)
Test complete.
Loading results page...
Fixes: 8
Slow Speeds?
At least that is consistent with the other results you are getting.
The next step is to run a BT speed test. This involves disconnecting, changing your login details to connect direct to BT and then running their speed test. Full instructions here.
grr
ME also in morning can get 7100 is v lucky but right now 980 grrr.
MAXDSL needs rename to MAXDiesel all TALK no SPEED.
Tongue
Slow Speeds?
Am on slow speeds too,
Downstream 124.9 Kbps ( = 0.1 Mbps )
Upstream 59.6 Kbps ( = 0.1 Mbps )
this from an BT IP Stream Office Max 20:1
Edit**
Just to Add have already did the BT speed tester and got 3775.0 kilo bits per second.
So it's not the exchange.
It's Green.
Slow Speeds?
Elvin, i have tried about 3 times to do a bt speedtest but cannot get it to work!! I have followed all instructions but can never get to the speedtest page!! Help!
Router i am using is Linksys Wag54GS, i have changed login in name etc but still can't get the damn thind to work
Slow Speeds?
username: speedtest@speedtest_domain
password:
http://speedtester.bt.com - if you are using BT's DNS servers
http://217.35.209.142 or http://217.32.105.42 - if you are using PlusNet DNS servers
bluewhale
i found putting the password as testing got it to work..
pity getting the speed to stabalise wasn't so esy :-)
Slow Speeds?
i have done all that and tried changing the dns numbers but still will not work. the router will still not connect!! HELP! am i doing something wrong? i have followed all instructions but still no luck. if i google bt speedtest and do it that way i got a result of 819 but i assume that this would not be accurate?
Another result I got from the speakeasy test was
1000kbps down
101kbps up
Slow Speeds?
HOORAY!! got the speedtester to work properly and the results for the UK jury were..........1981kpbs down!! and ideas anyone?
Fixes: 8
Slow Speeds?
That means it's down to Plusnet - raise a question giving the speedtest results.
Slow Speeds?
thats what i think also.............when i get slow speeds around 400k, i connect to the bt speedtester and can attain in excess or 3-4mb, so my connection to bt is working, its got to be plusnet side of things
Slow Speeds?
Slow Speeds indeed, i think my speed are just being shaped. And i wanna know how i managed to get a result of 0!
Date Time Result
24-05-2006 01:03:00 1902.6
24-05-2006 01:01:12 0
24-05-2006 00:22:57 1667.2
24-05-2006 00:22:32 1622.7
23-05-2006 23:18:59 780.4
23-05-2006 23:18:27 874.9
23-05-2006 19:49:39 1045.1
23-05-2006 19:48:36 997
