Slow Speed
fraval
Slow Speed
Just done a BT speed test
came back with 778[kpbs] for a 1.7MB file ,is this about normal for a 2MB service??
many thaks to any answers
Frav
shellsong
Slow Speed
At this time of day I would have thought it somewhat slow-- depends on how persistent it is though and BT probably wouldn't act on those sort of results unless something else seemed to be going on as well!
James
Re: Slow Speed
Frav
If you take a look at ServiceStatus, you will see that we experienced some propblems earlier this afternoon, which may have led to degraded speeds and latency. Without being certain, I would have expected that to have contributed to your problem.
JonathanW
Slow Speed
Actually, provided you logged into the BT Speed Checker using the test username and password our issues earlier shouldn't have had any effect on your results.
Though the speeds are still within the guidelines set by BTw, the best thing to do would be to run another test later on today and then a third one some time after midnight, and if these are also slow then run through the automated faults system so that our engineers can look into it further.
fraval
thanks for reply,s
thanks a lot everyone for the replies
