Slow I tunes download
Currently downloading itunes - only getting 10KB/s
Is there any special throttling applied to itunes, or is it just the site that is slow at the mo.
On premier by the way.
James
It's an issue at our end.
Currently iTunes traffic is being picked up by the Ellacoya's as P2P. There's a fix rolling out Thursday morning which should fix this.
Liam
We have identified an issue with itunes traffic that is due to be resolved on Thursday morning.
Currently it would appear we are incorrectly classifying it.
Hopefully the change being made on Thursday will resolve it for you - as itunes should be a priority application.
James
Slacker.
London Busses Cheesy Cheesy
Thanks for the reply (s)
Odd though - because I am not downloading music - just the itunes program via http (I think). So have the ellacoyas simply identified the itunes download *site* as PTP?
Cheers.
Liam
Whoops...
Sorry guys
This is still not right - now getting a wopping 25kB/s.
Not exactly a priority download.
Liam
Are you able to run Wireshark packet capture whilst downloading so that we can make sure it's correctly identified?
20 seconds of capturing and post the output file into a ticket for the attention of our network team would be good?
I'm guessing normal web browsing is performing better?
OK - after a little messing about;
here is the ticket ID: 21059806
And please note - as stated above, the speed issue is with downloading the itunes application, NOT itunes songs (I haven't tried that recently)
Wow! Sounds like a first Wink
James
And should now be fixed as of yesterday.
And indeed it is.
Now getting about 130kB/s which is a heck of a lot better than 10 - still not brilliant though
Having said that - this morinng as a quick test, I was getting nearly 800kB/s
So I'll put the speed now down to server/exchange loading.
Thanks all.
