Slow FTP
Slow FTP
For a while now my FTP sites are real slow, downloading seems fine when it gets going but the problem is uploading and navigating. It takes 5 seconds just to navigate into new folders and carry out commands like renaming, and uploads are around 10kb/s.
I did a traceroute and got this:
5 ge-4-1.metro2-londencyh00.london1.level3.net (212.113.11.41) 38.259 ms 43.410 ms 40.387 ms
6 so-1-2-0.gar2.london1.level3.net (212.113.0.11Cool 37.974 ms 44.169 ms 38.629 ms
7 ae-29-56.ebr2.london1.level3.net (4.68.116.190) 47.093 ms * *
8 * * *
9 ae-2.ebr1.newark1.level3.net (4.69.132.9Cool 111.168 ms 109.819 ms 120.732 ms
To be honest, I know not much what this stuff means, but understand the *** indicates there's a problem. Anything that can be done to improve this?
Plusnet Staff
Plusnet Staff
Slow FTP
The trace may or may not indicate the cause of the problem, certainly packets timing out aren't a good thing but they may not necessarily mean that there's anything wrong (some routers set responding to ping as the lowest priority and dedicate run time to routing traffic so some pings may just get dropped when it's busy).
As a comparison have you tried uploading to your PlusNet webspace (ftp.plus.net)?
Slow FTP
Hi
FTP.plus.net is lighting fast, I can navigate folders as if they were on my hard drive almost.
I have a bunch of servers in the US and some in manchester and all these, in comparison are dog slow.
So, I'm slightly confused where the problem is?
Plusnet Staff
Plusnet Staff
Slow FTP
Does it make any difference if you try at a different time of day (e.g. peak and off peak)? Are you using the same FTP client and connecting to the same port on the other servers as you just tried with the PlusNet server?
Are you able to try any other FTP servers? e.g. ftp.microsoft.com or try the servers you use from elsewhere?
Difficult to say exactly what the cause is, could be the server, the route to the server, the traffic being misidentified or something else.
Slow FTP
My mum who lives over the road has Bulldog, I went over today with the same laptop and the difference is amazing!!!
All my FTP sites are lightening fast, I come straight back home and back on plusnet it's slow as treacle. Traceroutes show no probems over on bulldog either.
And btw, it doesn't make any difference what time of day.
What exactly can I do about this? really dissapointing.
Firejack
Slow FTP
I've had a ticket open on the issue for a couple of weeks now. UPLOADS on various protocols are being throttled or managed by the Ellacoyas even though they shouldn't be.
I setup an FTP server on my home machine and had James (Mr Bailey of Plusnet that is) test out the upload speed and his download speed was terrible, therefore proving something is horribly wrong with uploads.
Just testing my FTP upload again right now gives 3.04KB/sec. I think I'll go update my ticket.
At least I know it definitely not my end now. So thanks for posting hoice Smiley
James
Slow FTP
Think I'm due another long night Smiley
I'll try and do some testing when I get in from the office.
Slow FTP
So has this got anything to do with these traceroutes?
Almost every site I traceroute has *, and it's always on level3.net. The traceroutes I did from the bulldog account had none of these.
re FTP, seem to be stuck at around 10kb/sec upload. Browsing is the worst though, having to wait 5 seconds after every command is so annoying.
Traceroute has started ...
traceroute: Warning: google.com has multiple addresses; using 64.233.167.99
traceroute to google.com (64.233.167.99), 64 hops max, 40 byte packets
1 192.168.1.1 (192.168.1.1) 2.107 ms 1.334 ms 1.305 ms
2 lo0-plusnet.pte-ag2.plus.net (195.166.128.72) 40.901 ms 47.749 ms 38.843 ms
3 ge0-0-0-504.pte-gw1.plus.net (84.92.4.89) 41.670 ms 39.764 ms 38.746 ms
4 ge0-0-0-22.ptn-gw1.plus.net (212.159.4.1) 40.219 ms 72.993 ms 41.021 ms
5 ge-4-1.metro2-londencyh00.london1.level3.net (212.113.11.41) 52.410 ms 37.434 ms 73.882 ms
6 so-1-3-0.gar1.london1.level3.net (212.113.3.25) 42.104 ms 39.320 ms 40.578 ms
7 ae-19-51.ebr1.london1.level3.net (4.68.116.30) 37.515 ms ae-19-55.ebr1.london1.level3.net (4.68.116.15Cool 51.487 ms ae-19-51.ebr1.london1.level3.net (4.68.116.30) 55.570 ms
8 * ae-1-100.ebr2.london1.level3.net (4.69.132.11Cool 72.327 ms 40.678 ms
9 * * ae-4.ebr1.newyork1.level3.net (4.69.132.109) 113.797 ms
10 * ae-1-100.ebr2.newyork1.level3.net (4.69.132.26) 121.449 ms *
11 * ae-2.ebr1.chicago1.level3.net (4.69.132.65) 135.753 ms *
12 ae-11-55.car1.chicago1.level3.net (4.68.101.130) 161.829 ms ae-11-51.car1.chicago1.level3.net (4.68.101.2) 130.376 ms ae-11-53.car1.chicago1.level3.net (4.68.101.66) 131.612 ms
13 google-inc.car1.chicago1.level3.net (4.79.208.1Cool 323.864 ms 292.995 ms 300.259 ms
14 66.249.94.133 (66.249.94.133) 298.724 ms 303.349 ms 72.14.232.53 (72.14.232.53) 306.182 ms
15 72.14.232.70 (72.14.232.70) 354.145 ms 64.233.175.26 (64.233.175.26) 329.846 ms 72.14.232.70 (72.14.232.70) 311.829 ms
16 py-in-f99.google.com (64.233.167.99) 308.610 ms 346.315 ms 346.604 ms
James
Slow FTP
That's cross-atlantic (hence the >100ms hops).
Do you get similar with UK FTP sites?
Slow FTP
it seems so.
I only have one UK server, and that's in London(not manchester as I thought) and it too is really really slow.
FTP.bbc.co.uk is really slow, every one I try from here is the same http://www.ftp-sites.org/anonymous_ftp_sites_list_uk_1.html
ftp.plus.net is great though.
James
Slow FTP
Currently FTP for Broadband Premier is in Silver, with internal FTP being Gold, hence the improved speeds you'll be seeing.
Silver traffic shouldn't be giving a dire service though. Like I said, I'll have a play tonight. Seeing as I don't have a life Smiley
Slow FTP
So premier is on silver? what has to happen for one to get on 'gold'..?
sounds like a debarkle. :roll:
James
Slow FTP
All traffic on PAYG is in Gold.
Fixes: 8
Slow FTP
Gold on PAYG is not all it's cracked up to be. I've been having a problem with VPN dropping out - details here. As part of the diagnostics, all my traffic has been moved up to Titanium. So far I am seeing fewer problems with the VPN - but browsing etc. seems much smoother.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
dod
Slow FTP
I've had slow uploads on FTP for months, to plusnet space and personal space, raised a ticket and all I got was "We're looking into it", never resolved.
