Slow Access
Slow Access
For the past couple of days, I have been lucky if I can reach 1kps transfer rate!
I have to admit, I don't usually have problems with it, only seems to have appeared of late.
My Modem is a Courier vEverything with the 56k Upgrade running through Smoothwall Firewall.
Has there been any issues with transfers through the 0808 numbers?
Best Regards
Chris
RE: Slow Access
Good Morning,
There are no genric issues currently on the 0808 number. This may be a localised FRIACO fault.
The best thing you can do is to raise this via Contact Us.
We can pass your details to BT for investigation and they should be able to resolve your problem.
Kind Regards
Duncan
| Duncan Scotland          Unmetered & ADSL solutions
| Senior Technical Consultant   for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ------- My Referrals - It pays to recommend PlusNet ---------
RE: Slow Access
0808 numbers?
> Good Morning,
Thanks Duncan, I have now raised it via Contact Us.
Thanks for your prompt reply.
Best Regards
Chris
RE: Slow Access
Hi again,
Great. I'll look into this shortly.
No problem.
Kind Regards
Duncan
Another Speed Isssue
Is it just me, or are other users finding that the service is running seriously slow this evening.
I am experiencing this even after reconnecting about six times.
Any comments?
Stephen Creasey
RE: Another Speed Isssue
Yes, same for me.
I've raised a ticket on it, too.
Thanks,
We can then look into it closely.
Chris
| Chris Rugen ............................... Unmetered & ADSL solutions
| Senior Technical Consultant ................... for Home & Business
| PlusNet Technologies Ltd .......................... http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----------
