Slow ADSL
Slow ADSL
Hi support,
A few weeks ago i posted a message regarding a very slow connection on my adsl and windows xp, no one could answer the question.
Since then i have tried a check from the following site
http://www.dslreports.com/tweaks
I then followed their recommendations to adjust the recwin settings for my connection and hey presto fast as ever.
So if anyone else is suffering from the same problem i have found the answer
Hope this helps and that you can pass this info on if anyone else has the same problem
Regards
Ged Hopwood
1 REPLY
RE: Slow ADSL
> Hi support,
Hi Ged,
Thank you for the above link. I am sure many people will find it helpful.
Regards,
Dave
| David Scarpa...................Unmetered & ADSL solutions
| Senior Technical Consultant...........for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
