Simple question !
Simple question !
Come the 3rd april will i still be able to download from an external news server? It`s just PN`s own news server and p2p to be scrapped, am i correct?
Cheers all.
Simple question !
Plusnet dont do simple!!
you can see that from the useage guides :shock:
Simple question !
I know the capping is still in force but are they closing ports 119 and 8000 ?
Simple question !
no, no you can still use 3rd party usenet and the text only usenet from PN
Simple question !
Many thanks, so it`s not as bad as people are making out, i`ve always used an external server and that wont be affected so i`m ok with the changes.
Simple question !
And to correct another item in your first post, P2P is not being scrapped, heavily traffic shaped yes, but not scrapped.
flyer99
Simple question !
So if we opt to use an external news server are plusnet going to still apply management to NNTP ports as before ? :roll:
Simple question !
Yep, as explained elsewhere regardless of where the usenet server is located the same amount of bandwidth on the BT Centrals is still going to be used so it will still be subject to the same limits... though as completion rates should be higher I suspect people won't have to retry as much etc...
