Signal to noise ratio
What are good signal to noise values? is this the same as line attenuation etc?
ta Smiley
shellsong
just checked mine and got this HELP.
Congratulations, you are in a broadband enabled area.
However, there appears to a compatibility issue with your phone line. This could be caused by an existing broadband connection, ISDN, a DACS unit, TPON, a pending ADSL order or many other common issues
what does this mean
chellemtd2, if you've already got a broadband account then the checker will detect that and tell you. Have you already got broadband?
