Should I upgrade to MaxDSL ?
Due to the distance to the exchange from my house (the DMT utility says about 7 - 9km) I'm currently limited to a 512k connection.
B Thave actually been to the house and stated that I can't get BB at all Cry , but with the right choice for modem, I've been online for a year now Cheesy
My downstream line stats are not brilliant (about 63db and between 4 and 12 SNR). Today the SNR is actually -3 :shock: but it's cloudy ...
Anyway, I was just wondering if I should go for a MaxDSL upgrade.
Is my SNR just too low to see any benefit ?
If I did upgrade, might I risk losing my (already flakey) connection ?
Thanks for any help
Mark
Re: Should I upgrade to MaxDSL ?
I have never heard of MaxDSL making a line more stable, so make from that what you will.
I would not do it.
SW.
3Mb FTTC
Alecto
Max gives you a higher speed by reducing the SNR it will accept down to 6dB.
In your case, it's already there or below, so if you've got a stable-ish connection, albeit slow, with those figures, I'd stick with it.
Mand
Hi
I wouldn't risk it either personally.
I've heard tell of people upgrading to Max, it not working and then requesting their old service, but BT refusing due to line conditions.
That said, it could work, give you a speed increase and have no issues.
The joys of Max........ :?
Thanks for the replies.
I think they just confirm my suspicions that upgrading might be a bad thing, so I'll stick with my 512k and be grateful.
Now I've just got to wait for Pipex to roll out MaxDSL to all their Business BB users and I'll be happy. 2Mb just seems a bit slow now ... Wink
Luzern
Seasoned Pro
May I ask a question? What is the DMT utilty? Will i he;p me to decide if upgrade is worthwhile? BTW my area code is 01425
It's the DSL Modem Tool, available for most ADSL modems from http://dmt.mhilfe.de
Not sure about this ... maybe someone else can answer that.
Luzern
Seasoned Pro
Is there a version in Englsih?
Nein :lol:
Luzern
Seasoned Pro
Und danke schoen, mein sehr geehrte Herr Cheesy
Stop showing off!
Stop showing off!
I have to admit that even for "nein" I had to check with babelfish ... Shockedops:
