Setting Data Transfer Watch
thehatman
If I set the "Data Transfer Watch" tool to "0" will that prevent any charge over my subscription occuring even if I run up to my limit?
I'm on PAYG, 15GB included.
thehatman
Anyone know this?
It would be a good way of not over-spending?
Can a PN person say?
Thanks Smiley
I think they are in denial...
I'm om the minimum PAYG, and mine says under the box where you enter the amount:
Minimum (based on current charges): £14.99 Why?
So I guess for a 15GB PAYG on the 'special deal', it would be £19.99 (if that is the right monthly amount).
@hatboy, if you had clicked on 'why' you would have seen more information on how to use the tool. Below is part of the explanation.
You can set the minimum amount to any figure you like, providing this figure is equal to or higher than your current total monthly subscription (including any extra charges for data transfer or product changes chosen this month such as changing your included amount or domain registration).
thehatman
Thanks.
is there a way of completely removing the data transfer watch after setting it?
it is giving me nothing but trouble
If you go to data_transfer_watch there is a cancel link next to your current amount. It will come back as 'not set' once you have cancelled it.
