Second Home
eglwys
Second Home
Hi
I have a second home and wish to add adsl there, I would like to use the same account / log-in. Does anybody know what my best option is please? also if I can use the same account / log-in and simply pay for the adsl will I be able to be log on from both simutaneously
Many Thanks
Martin
LiamM
Second Home
You will need to signup to a new service, with a new login.
What reason do you have for wanting to use the same login? All your email, webspace, cgi etc... can all be accessed from your Second Home using your original login as it is a PN Connection.
Unfortunately you cannot have two ADSL Connections using the same login, at the same time.
Second Home
You could signup for a more basic account such as a Lite account at the mew location and still login using your main account, that way you shouldnt have any extra bandwidth charges etc, but im not 100% sure.
The speed of the connection is line dependant through. Not account dependant. So if you only signed up for a lower speed account at the new location then you would never get a higher speed (bulk speed rollouts aside).
Chris
eglwys
Second Home
Many Thanks both
Martin
