SSI Server Side Includes?
Does anyone know if we get SSIs on our normal web server. On a previous ISP I could use an SSI to call a standard block of html code from every page. That way I could keep one copy of my banner and menu system and include it on every page. I think the command was "include" or similar. I know that the FrontPage server would probably do this, but I don't use FP. I know I could use frames, but would prefer not to as I don't like the way frames mess up peoples "favourites" linking etc.
RE: SSI Server Side Includes?
I am fairly sure that you can only use SSI for pages that are located on your CGI space. Bit of a pain I'm afraid but thats the way that Plusnet have it organised.
I have overcome this with my Model Railway Webpages by greating a standard blank page that I use as a template for any new pages.
This template has all the links to the graphics and return to home page built in and I store all the often used graphics in their own folder.
This way I only need one copy that can be called from any page on the site and only need to add the text and pictures relevent to that page.
Regards
http://www.hmrg.co.uk
To make SSI work in your regular webspace, you will need to add the following directive in an .htaccess file:
AddType text/html .shtml
AddHandler server-parsed .shtml
This will allow you to use SSI, with the exception of Exec statements.
Regards,
Mike
| Mike Grice....................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd.........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
That's exactly what I wanted to hear, all is working great now.
Many thanks Mike (PlusNet Support)
and for your suggestions John.
Not a problem BobbyV. Let us know if you have any problems.
Regards,
Mike
Well, one thing Mike; I want the default index page to now be index.shtml and therefore added the following entry to my .htaccess file (which I have placed in the htdocs folder):
DirectoryIndex index.shtml index.html index.htm
but the default page is still index.htm. If I delete that, it still doesn't server up the index.shtml file, just a directory listing.
I would like to keep an old index.htm file (with just a re-direct to index.shtml) in case people are linking to my URL with the index.htm in their link.
What have I missed?
Should my .htaccess file be in the root?
Bob
> What have I missed?
> Bob
Hi Bob,
I think the problem here is that the main homepages server will not allow DirectoryIndex as an .htaccess directive.
I'd personally stick with a redirect page with something like a meta redirect tag in the headers.
Regards,
Mike
Wow, that's fast!
I understand Mike and that explains it. Is there anywhere on PlusNet where I can find out what directives are available to users, I did look some time ago but found nothing?
Bob
> Wow, that's fast!
I don't believe there is a list, but I'll see if I can press networks into providing me with a list :-)
Regards,
Mike
