SLowing down again on LLU
kreynolds
Currently connected to thn-ag3
Speedtest on own login
Your current bandwidth reading is:
3.12 Mbps
which means you can download at 398.88 KB/sec. from our servers.
28.8 kbps dial-up
33.6 kbps dial-up
53.3 kbps dial-up
56 kbps ISDN
128 kbps ISDN
150 kbps DSL
256 kbps DSL
512 kbps DSL
3191 kbps YOU
Please retain the following information if you wish to contact Customer Services
Your reference number is 3191-9374939
Speedtest on test login
6.74 Mbps
which means you can download at 862.2 KB/sec. from our servers.
28.8 kbps dial-up
33.6 kbps dial-up
53.3 kbps dial-up
56 kbps ISDN
128 kbps ISDN
150 kbps DSL
256 kbps DSL
512 kbps DSL
6897.6 kbps YOU
Your reference number is 6897-9374967
Ping results
C:\Documents and Settings\Karl>ping plus.net
Pinging plus.net [212.159.8.137] with 32 bytes of data:
Reply from 212.159.8.137: bytes=32 time=60ms TTL=249
Reply from 212.159.8.137: bytes=32 time=105ms TTL=249
Reply from 212.159.8.137: bytes=32 time=55ms TTL=249
Ping statistics for 212.159.8.137:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 55ms, Maximum = 105ms, Average = 68ms
Tracert results
C:\Documents and Settings\Karl>tracert plus.net
Tracing route to plus.net [212.159.8.137]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 50 ms 50 ms 50 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 49 ms 48 ms 48 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 49 ms 50 ms 50 ms ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
5 51 ms 53 ms 51 ms gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
6 59 ms 60 ms 59 ms se3-0.pih-gw1.plus.net [195.166.129.250]
7 55 ms 56 ms 56 ms vlan8.pih-gw4.plus.net [212.159.0.30]
8 56 ms 56 ms 56 ms pih-al4.plus.net [212.159.1.36]
9 57 ms 58 ms 58 ms portal.plus.net [212.159.8.137]
Trace complete.
Seems like the problem is at Plus Net's end again
Plusnet Staff
Plusnet Staff
Not seen any other reports of problems, have you tried disconnecting and reconnecting a few times and see if that makes a difference (it did for some people previously)?
kreynolds
Hardly better Sad Sad Sad
Speedtest own login
3.84 Mbps
which means you can download at 491.53 KB/sec. from our servers.
28.8 kbps dial-up
33.6 kbps dial-up
53.3 kbps dial-up
56 kbps ISDN
128 kbps ISDN
150 kbps DSL
256 kbps DSL
512 kbps DSL
3932.2 kbps YOU
Your reference number is 3932-9378863
Ping result
Reply from 212.159.8.137: bytes=32 time=56ms TTL=249
Reply from 212.159.8.137: bytes=32 time=57ms TTL=249
Reply from 212.159.8.137: bytes=32 time=53ms TTL=249
Reply from 212.159.8.137: bytes=32 time=59ms TTL=249
Minimum = 53ms, Maximum = 59ms, Average = 56ms
Tracert
2 50 ms 51 ms 50 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 40 ms 40 ms 40 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 46 ms 44 ms 46 ms ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
5 51 ms 50 ms 50 ms gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
6 59 ms * 56 ms se3-0.pih-gw1.plus.net [195.166.129.250]
7 58 ms 57 ms 59 ms vlan8.pih-gw4.plus.net [212.159.0.30]
8 52 ms 52 ms 55 ms pih-al4.plus.net [212.159.1.36]
9 51 ms 50 ms 52 ms portal.plus.net [212.159.8.137]
Trace complete.
Sad
kreynolds
Today is even worse than yesterday
Speetest own login
1.45 Mbps
which means you can download at 185.49 KB/sec. from our servers.
28.8 kbps dial-up
33.6 kbps dial-up
53.3 kbps dial-up
56 kbps ISDN
128 kbps ISDN
150 kbps DSL
256 kbps DSL
512 kbps DSL
1483.9 kbps YOU
Your reference number is 1483-9389418
Speedtest test login
6.68 Mbps
which means you can download at 855 KB/sec. from our servers.
28.8 kbps dial-up
33.6 kbps dial-up
53.3 kbps dial-up
56 kbps ISDN
128 kbps ISDN
150 kbps DSL
256 kbps DSL
512 kbps DSL
6840 kbps YOU
Your reference number is 6840-9389394
Ping results
C:\Documents and Settings\Karl>ping bbc.co.uk
Pinging bbc.co.uk [212.58.224.131] with 32 bytes of data:
Reply from 212.58.224.131: bytes=32 time=47ms TTL=120
Reply from 212.58.224.131: bytes=32 time=50ms TTL=120
Reply from 212.58.224.131: bytes=32 time=49ms TTL=120
Ping statistics for 212.58.224.131:
Minimum = 47ms, Maximum = 50ms, Average = 48ms
Reply from 212.159.8.137: bytes=32 time=58ms TTL=249
Minimum = 56ms, Maximum = 58ms, Average = 57ms
tracert results
C:\Documents and Settings\Karl>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.224.131]
1 1 ms <1 ms <1 ms 192.168.0.1
2 51 ms 48 ms 49 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 49 ms 48 ms 49 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 50 ms 49 ms 51 ms ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
5 49 ms 47 ms 48 ms gi1-1-22.ptn-gw5.plus.net [212.159.4.6]
6 47 ms 50 ms 50 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 51 ms 48 ms 46 ms 212.58.238.149
8 51 ms 50 ms 50 ms rdirwww-vip.thdo.bbc.co.uk [212.58.224.131]
Trace complete.
2 50 ms 48 ms 47 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 175 ms 122 ms 223 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 50 ms 49 ms 50 ms ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
5 51 ms 47 ms 47 ms gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
6 59 ms 56 ms 56 ms se3-0.pih-gw1.plus.net [195.166.129.250]
7 58 ms 58 ms 58 ms vlan8.pih-gw4.plus.net [212.159.0.30]
8 59 ms 57 ms 57 ms pih-al4.plus.net [212.159.1.36]
9 59 ms 61 ms 58 ms portal.plus.net [212.159.8.137]
Trace complete.
echoecho
From having a stable 3800 kbps for the past 3 weeks or so, I am down to just over 1000.
I have rebooted several times ... LLU is so exciting! You never know what speed you're going to get.
kreynolds
00:00 to 0:600 speeds are fine
14/07/07 05:45
Speedtest own login
6.51 Mbps
which means you can download at 832.98 KB/sec. from our servers.
28.8 kbps dial-up
33.6 kbps dial-up
53.3 kbps dial-up
56 kbps ISDN
128 kbps ISDN
150 kbps DSL
256 kbps DSL
512 kbps DSL
6663.8 kbps YOU
Your reference number is 6663-9397100
6.80 Mbps
which means you can download at 870.01 KB/sec. from our servers.
28.8 kbps dial-up
33.6 kbps dial-up
53.3 kbps dial-up
56 kbps ISDN
128 kbps ISDN
150 kbps DSL
256 kbps DSL
512 kbps DSL
6960.1 kbps YOU
Your reference number is 6960-9397110
Ping results
Reply from 212.58.224.131: bytes=32 time=40ms TTL=120
Reply from 212.58.224.131: bytes=32 time=37ms TTL=120
Reply from 212.58.224.131: bytes=32 time=38ms TTL=120
Minimum = 37ms, Maximum = 40ms, Average = 38ms
Reply from 212.159.8.137: bytes=32 time=45ms TTL=249
Reply from 212.159.8.137: bytes=32 time=44ms TTL=249
Minimum = 44ms, Maximum = 45ms, Average = 44ms
Tracert results
2 39 ms 39 ms 41 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 38 ms 38 ms 38 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 39 ms 38 ms 79 ms ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
5 38 ms 37 ms 38 ms gi1-1-22.ptn-gw5.plus.net [212.159.4.6]
6 40 ms 39 ms 38 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 40 ms 37 ms 37 ms 212.58.238.149
8 39 ms 37 ms 38 ms rdirwww-vip.thdo.bbc.co.uk [212.58.224.131]
Trace complete.
2 39 ms 38 ms 38 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 38 ms 37 ms 37 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 39 ms 38 ms 37 ms ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
5 39 ms 39 ms 38 ms gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
6 47 ms 45 ms 46 ms se3-0.pih-gw1.plus.net [195.166.129.250]
7 46 ms 46 ms 46 ms vlan8.pih-gw4.plus.net [212.159.0.30]
8 45 ms 45 ms 44 ms pih-al4.plus.net [212.159.1.36]
9 45 ms 46 ms 45 ms portal.plus.net [212.159.8.137]
Trace complete.
Ticket 22351821 raised 13/07/07 15:00, still waiting for reply.
From the speedtest on the testing@dslconnect.co.uk login, the speed is at my normal rate, seems like the slowdown is with Plus Net.
kreynolds
25 hours and 14 mins and no reply to my open ticket Evil Evil Evil Evil
14/07/07 16:57
Speedtest own login
3.12 Mbps
which means you can download at 399.58 KB/sec. from our servers.
28.8 kbps dial-up
33.6 kbps dial-up
53.3 kbps dial-up
56 kbps ISDN
128 kbps ISDN
150 kbps DSL
256 kbps DSL
512 kbps DSL
3196.6 kbps YOU
Your reference number is 3196-9402573
6.65 Mbps
which means you can download at 850.98 KB/sec. from our servers.
28.8 kbps dial-up
33.6 kbps dial-up
53.3 kbps dial-up
56 kbps ISDN
128 kbps ISDN
150 kbps DSL
256 kbps DSL
512 kbps DSL
6807.8 kbps YOU
Your reference number is 6807-9402549
Ping results
Reply from 212.58.224.131: bytes=32 time=52ms TTL=120
Reply from 212.58.224.131: bytes=32 time=43ms TTL=120
Minimum = 37ms, Maximum = 52ms, Average = 42ms
Reply from 212.159.8.137: bytes=32 time=47ms TTL=249
Reply from 212.159.8.137: bytes=32 time=46ms TTL=249
Reply from 212.159.8.137: bytes=32 time=54ms TTL=249
Reply from 212.159.8.137: bytes=32 time=49ms TTL=249
Minimum = 46ms, Maximum = 54ms, Average = 49ms
Tracert results
2 50 ms 48 ms 51 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 49 ms 46 ms 46 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 44 ms 43 ms 44 ms ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
5 45 ms 47 ms 45 ms gi1-1-22.ptn-gw5.plus.net [212.159.4.6]
6 43 ms 46 ms 44 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 43 ms 40 ms 44 ms 212.58.238.149
8 41 ms 38 ms 38 ms rdirwww-vip.thdo.bbc.co.uk [212.58.224.131]
Trace complete.
2 44 ms 44 ms 44 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 43 ms 45 ms 44 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 45 ms 47 ms 46 ms ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
5 58 ms 203 ms 110 ms gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
6 50 ms 48 ms 48 ms se3-0.pih-gw1.plus.net [195.166.129.250]
7 48 ms 46 ms 46 ms vlan8.pih-gw4.plus.net [212.159.0.30]
8 49 ms 48 ms 45 ms pih-al4.plus.net [212.159.1.36]
9 48 ms 47 ms 49 ms portal.plus.net [212.159.8.137]
Mand
Apologies for the delay, we are currently dealing with an increased number of faults, and are working through them as quickly as possible.
I've raised the fault now, and we should receive an update within 72 hours.
kreynolds
Thanks Mand
kreynolds
This gets worse, my profile has now been altered to
DownStream Connection Speed 190 kbps
UpStream Connection Speed 282 kbps
Why mess around with the profile when I'm not having any loss of synch!!!!!!!!!!!!!
