SAR110 + external access
Hi.
Has anyone been able to configure their SAR110 router for external access with SSH? (V1.37 - tried V1.38 but went back very quickly!)
I have an internal SSH server and thought all that I would need to do was create an RDR rule to redirect from PP0 to the Private IP address along with a filter rule as well?
I have tried different variations but without success.
If anyone can help with some simple instructions, I'd be most greatful.
Regards.
RE: SAR110 + external access
I've just done exactly that, although I didn't create the filter. Just the RDR rule, this is what I have set..
Rule ID : 2
Rule Flavor : RDR
IF Name: ppp-0
Protocol: TCP
Local Address From : 172.31.1.10
Local Address To : 172.31.1.10
Global Address From : 0.0.0.0
Global Address To : 0.0.0.0
Destination Port From : 22
Destination Port To : 22
Local Port : 22
Didn't have to do anything else, just that, works a treat for me.
Hope this helps
Regards
Chris
> Hi.
> Regards.
Actually, forgot one thing, I am running 1.38 and not 1.37
> Hi,
> Rule ID : 2
> Rule Flavor : RDR
> IF Name: ppp-0
> Protocol: TCP
> Local Port : 22
> Hope this helps
> Regards
> Chris
> > Hi.
> > Regards.
Thanks for your feedback Chris, just out of interest, how have you set the default actions for the interfaces?
I currently have low security level, private is accept, DMZ and Public are deny...
