Running like a one legged dog???
Rigga
For the first time I'm currently experiencing major internet treacle problems,(well it kinda feels like wading through treacle).
ADSL Guide speed test results,
Downstream 105 Kbps (13.1 KB/sec) 113 Kbps (inc. overheads)
Upstream 55 Kbps (6.9 KB/sec) 59 Kbps (inc. overheads)
Gaming pings are atrocious, around 1700ms
On premier option1, 2mb line.
Any ideas as to why, is the network busy perchance? or have I been placed on some sort of bad boy pipe for downloading my 5gb last month?
Ideas or help much appreciated.
R.
Ritey
yep im having probs as well it seems theres a problem....
Resolving Host: google.com...
[64.233.187.99]
Begining Trace...
TTL Host Ms Status
1 10.0.0.2 0 TTL_EXPIRED_TRANSIT
2 195.166.128.72 22 TTL_EXPIRED_TRANSIT
3 84.92.4.82 18 TTL_EXPIRED_TRANSIT
4 195.50.117.169 2225 TTL_EXPIRED_TRANSIT
5 4.68.116.162 62 TTL_EXPIRED_TRANSIT
6 64.159.3.254 90 TTL_EXPIRED_TRANSIT
7 4.68.121.179 89 TTL_EXPIRED_TRANSIT
8 4.79.18.198 93 TTL_EXPIRED_TRANSIT
9 72.14.238.232 91 TTL_EXPIRED_TRANSIT
10 72.14.238.97 101 TTL_EXPIRED_TRANSIT
11 72.14.236.173 104 TTL_EXPIRED_TRANSIT
12 64.233.187.99 -1 REQ_TIMED_OUT
Trace Complete
Same here.
Sites like the BBC loads fine, then the links seems to seize up - does nothing for about 10 seconds then draws the page. Never had this problem before. Help! It's doing it on all PCs in the house.
hiflier
And Here.
Trace routes are showing either timeouts or 1000ms times inside plusnets network.
I've rebooted and its still the same.
Anyone from CS hereaboutsHuh??
Ian.
Ritey
is Level (3) Communications ip address. So i dont think its plusnets fault.
But maybe they should get onto them....
same sort of crap. High latency on everything, DNS, WWW, games...
Low bandwidth too, 1k/s here.
Evil
Jeni
Tracing route to portal.plus.net [212.159.8.137]
over a maximum of 30 hops:
1 25 ms 19 ms 19 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
2 21 ms 19 ms 19 ms ge0-0-0-503.pte-gw1.plus.net [84.92.4.81]
3 29 ms 29 ms 29 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
4 27 ms 29 ms 29 ms vl4.sec.ptb-gw3.plus.net [195.166.129.227]
5 4133 ms 3929 ms 4009 ms if2.ptb-al1.plus.net [195.166.129.39]
6 3528 ms 3499 ms 3859 ms portal.plus.net [212.159.8.137]
Trace complete.
copy of my tracert to plusnet, everythnig was ok about 30 minutes ago, now im struggling to get pages to load in etc.
Suddenly has improved here, but don't know if it's temporary.
hiflier
@thatplace.
That's exactly what I'm seeing, and at the same point in the route.
So it's not "Us".
Ian.
passer
It's always bad on Monday evenings Sad
My browsing, inc. BBC seems fine, but P2P took a dive.
Some very heavy management kicked in at 19:30 - don't know if its BT or Ellacoya - some sort of load balancing or shaping I suspect.On track record, it'll ease up later, an hour or two.
Ritey
not improved for me Sad
Rigga
Nor me, Still crawling.... yyyyyyyyyyyaaaaaaaaaawwwwwwwwwwwwwnnnnnn Smiley
I rebooted my router to establish a new connection.
Rigga
Done that several times, maybe i'm just unlucky Sad
If it's external to PN how come the PN pages are also loading very sssslllllllooooooowwwwwwwwwlllllllyyyyyyyyyyy..... ?
R.
Jeni
did it make a differenceHuh
