Router losing connection - Looking for help
Not getting any answer against my ticket so perhaps I'll get some here.
The is a copy of my entire ticket -
Question topic: Raise a Fault | ID: 19914580 Open
Your original question 8:09am, Wednesday 26th July 2006
[Support Wizard Journey]
[Self-test your Connection and Raise a Fault]
[Additional Information]
I was recently regraded to LLU and since then I have had problems with my connection. Since I was unable to get speeds above 2Mb I bought a new router. This was successfully able to connect me at speeds more acceptable (just over 7Mb)
The main problem is my router now loses synch and drops connection on a regular basis.
This is a big problem since it means that when I am playing online games I am constantly dropped making the gaming almost worthless.
Before the regrade I had absolutely no problems whatsoever. This suggests to me that I have problems BECAUSE of the regrade.
I know that the standard answer is to test the line (this has previously been done whilst being regraded) and to plug directly into the master socket and to try new filters (already tried new filters) and to try this that the other.
Having read the forums, I know that a lot of people have the same issue where they start to have problems AFTER they are regraded. This would indicate to me a bigger problem than suddenly everybodies equipment has failed or that suddenly everybodies line has failed.
Since I have only recently been regraded to LLU (Tuesday 18th I lost my connection, Sunday 23rd I got it back) could you please confirm whether or not these problems could be related to maximum speed tests on my line. Would I expect this problem to go away after a period of time?
Here are my line stats :
ADSL Status
ADSL status shows the ADSL physical layer status.
ADSL Firmware Version: 5.00.04.00 - 5.00.03.00 - 5.00.03.00 Annex A - 01.07.2b - 0.52
ADSL Software Version: V3.00B01T02.UK-A.20060208
Line State Connected
Modulation ADSL_2plus
Annex Mode ANNEX_A
Max Tx Power -38 dBm/Hz
Item Downstream Upstream
SNR Margin 15 12 dB
Line Attenuation 24 10 dB
Data Rate 8157 618 kbps
And here is a copy of my log from last night -
Jul 26 02:11:54> WAN IP address 84.92.115.207
Jul 26 02:11:54> WAN gateway 195.166.128.53
Jul 26 02:11:54> primary DNS address 212.159.6.10
Jul 26 02:11:54> secondary DNS address 212.159.6.9
Jul 26 02:12:33> DSL out of sync
Jul 26 02:12:33> DSL in Sync
Jul 26 02:22:59> DSL out of sync
Jul 26 02:22:59> DSL in Sync
Jul 26 02:37:33> DSL out of sync
Jul 26 02:37:56> DSL in Sync
Jul 26 02:38:02> sar read trained mode (5)(ADSL_2plus)
Jul 26 02:38:03> PPPD Terminated Through Signal
Jul 26 02:38:03> Connection terminated.
Jul 26 02:38:03> pingStat 2, oamHdr 230 result 0
Jul 26 02:38:03> pingStat 2, oamHdr 200 result 0
Jul 26 02:38:03> pingStat 2, oamHdr 280 result 0
Jul 26 02:38:03> pingStat 2, oamHdr 240 result 0
Jul 26 02:38:03> pingStat 2, oamHdr 260 result 0
Jul 26 02:38:03> pingStat 2, oamHdr 600 result 0
Jul 26 02:38:03> pingStat 2, oamHdr 800230 result 0
Jul 26 02:38:03> pingStat 2, oamHdr 2B0 result 0
Jul 26 02:38:03> pingStat 2, oamHdr 330 result 0
Jul 26 02:38:03> pppd 2.4.1 started by root, uid 0
Jul 26 02:38:03> Connect: ppp0 {--}
Jul 26 02:38:03> pingStat 2, oamHdr 3B0 result 0
Jul 26 02:38:03> pingStat 2, oamHdr 8002B0 result 0
Jul 26 02:38:03> pingStat 2, oamHdr 800330 result 0
Jul 26 02:38:03> pingStat 2, oamHdr 8003B0 result 0
Jul 26 02:38:03> ppp0
Jul 26 02:38:03> closing 0.0.38.5
Jul 26 02:38:03> tn7sar_teardown_complete called for channel 0
Jul 26 02:38:03> ChannelTeardown returned rc = 0
Jul 26 02:38:04> WAN IP address 84.92.115.207
Jul 26 02:38:04> WAN gateway 195.166.128.53
Jul 26 02:38:04> primary DNS address 212.159.6.10
Jul 26 02:38:04> secondary DNS address 212.159.6.9
Jul 26 02:38:04> ppp0
Jul 26 03:40:52> DSL out of sync
Jul 26 03:41:14> DSL in Sync
ul 26 03:41:23> sar read trained mode (5)(ADSL_2plus)
Jul 26 03:41:24> PPPD Terminated Through Signal
Jul 26 03:41:24> Connection terminated.
Jul 26 03:41:24> pingStat 2, oamHdr 230 result 0
Jul 26 03:41:24> pingStat 2, oamHdr 200 result 0
Jul 26 03:41:24> pingStat 2, oamHdr 280 result 0
Jul 26 03:41:24> pingStat 2, oamHdr 240 result 0
Jul 26 03:41:24> pingStat 2, oamHdr 260 result 0
Jul 26 03:41:24> pingStat 2, oamHdr 600 result 0
Jul 26 03:41:24> pppd 2.4.1 started by root, uid 0
Jul 26 03:41:24> Connect: ppp0 {--}
Jul 26 03:41:24> pingStat 2, oamHdr 800230 result 0
Jul 26 03:41:24> pingStat 2, oamHdr 2B0 result 0
Jul 26 03:41:24> pingStat 2, oamHdr 330 result 0
Jul 26 03:41:24> pingStat 2, oamHdr 3B0 result 0
Jul 26 03:41:24> pingStat 2, oamHdr 8002B0 result 0
Jul 26 03:41:24> pingStat 2, oamHdr 800330 result 0
Jul 26 03:41:24> pingStat 2, oamHdr 8003B0 result 0
Jul 26 03:41:24> ppp0
Jul 26 03:41:24> closing 0.0.38.5
Jul 26 03:41:24> tn7sar_teardown_complete called for channel 0
Jul 26 03:41:24> ChannelTeardown returned rc = 0
Jul 26 03:41:24> WAN IP address 84.92.115.207
Jul 26 03:41:24> WAN gateway 195.166.128.53
Jul 26 03:41:24> primary DNS address 212.159.6.10
Jul 26 03:41:24> secondary DNS address 212.159.6.9
Jul 26 04:41:40> DSL out of sync
Jul 26 04:42:04> DSL in Sync
Jul 26 04:42:12> sar read trained mode (5)(ADSL_2plus)
Jul 26 04:42:13> PPPD Terminated Through Signal
Jul 26 04:42:13> Connection terminated.
Jul 26 04:42:13> pingStat 2, oamHdr 230 result 0
Jul 26 04:42:13> pingStat 2, oamHdr 200 result 0
Jul 26 04:42:13> pingStat 2, oamHdr 280 result 0
Jul 26 04:42:13> pingStat 2, oamHdr 240 result 0
Jul 26 04:42:13> pingStat 2, oamHdr 260 result 0
Jul 26 04:42:13> pingStat 2, oamHdr 600 result 0
Jul 26 04:42:13> pppd 2.4.1 started by root, uid 0
Jul 26 04:42:13> pingStat 2, oamHdr 800230 result 0
Jul 26 04:42:14> Connect: ppp0 {--}
Jul 26 04:42:14> pingStat 2, oamHdr 2B0 result 0
Jul 26 04:42:14> pingStat 2, oamHdr 330 result 0
Jul 26 04:42:14> pingStat 2, oamHdr 3B0 result 0
Jul 26 04:42:14> pingStat 2, oamHdr 8002B0 result 0
Jul 26 04:42:14> pingStat 2, oamHdr 800330 result 0
Jul 26 04:42:14> pingStat 2, oamHdr 8003B0 result 0
Jul 26 04:42:14> ppp0
Jul 26 04:42:14> closing 0.0.38.5
Jul 26 04:42:14> tn7sar_teardown_complete called for channel 0
Jul 26 04:42:14> ChannelTeardown returned rc = 0
Jul 26 04:42:14> WAN IP address 84.92.115.207
Jul 26 04:42:14> WAN gateway 195.166.128.123
Jul 26 04:42:14> primary DNS address 212.159.6.10
Jul 26 04:42:14> secondary DNS address 212.159.6.9
Jul 26 04:58:14> Serial link appears to be disconnected.
Jul 26 04:58:14> ppp0
Jul 26 04:58:20> Terminated: Peer Not Responding to Echo Requests
Jul 26 04:58:20> Connection terminated.
Jul 26 04:58:20> pppd 2.4.1 started by root, uid 0
Jul 26 04:58:20> closing 0.0.38.5
Jul 26 04:58:20> tn7sar_teardown_complete called for channel 0
Jul 26 04:58:20> ChannelTeardown returned rc = 0
Jul 26 04:58:20> Connect: ppp0 {--}
Jul 26 04:58:50> PPP Negotiation Failed
Jul 26 04:58:50> LCP: timeout sending Config-Requests
Jul 26 04:58:50> Connection terminated.
Jul 26 04:58:50> closing 0.0.38.5
Jul 26 04:58:50> tn7sar_teardown_complete called for channel 0
Jul 26 04:58:50> ChannelTeardown returned rc = 0
Jul 26 04:58:50> pppd 2.4.1 started by root, uid 0
Jul 26 04:58:50> Connect: ppp0 {--}
Jul 26 04:59:20> LCP: timeout sending Config-Requests
Jul 26 04:59:20> Connection terminated.
Jul 26 04:59:20> closing 0.0.38.5
Jul 26 04:59:20> tn7sar_teardown_complete called for channel 0
Jul 26 04:59:20> ChannelTeardown returned rc = 0
Jul 26 04:59:20> PPP Negotiation Failed
Jul 26 04:59:20> pppd 2.4.1 started by root, uid 0
Jul 26 04:59:20> Connect: ppp0 {--}
Jul 26 04:59:32> ppp0
Jul 26 04:59:32> WAN IP address 84.92.115.207
Jul 26 04:59:33> WAN gateway 195.166.128.123
Jul 26 04:59:33> primary DNS address 212.159.6.10
Jul 26 04:59:33> secondary DNS address 212.159.6.9
I would appreciate your help with this.
Thank you
Your comment 6:23pm, Thursday 27th July 2006
More recently, my router has been disconnecting and unable to re-establish the connection until I reboot it. Once rebooted I am able to connect again (unfortunately at this point the log seems to be purged!)
Your comment 12:31pm, Friday 28th July 2006
My connection has dropped again some time between 11:40 and 12:00 (I upload a file every 20 minutes to my website - no file uploaded, no connection).
Still waiting for a reply to this ticket after over 50 hours waiting!!!
Your comment 1:05pm, Friday 28th July 2006
I have called up DLink (my router) and asked them about why my router disconnects but doesn't disconnect.
They have told me that my Line Attenuation is too high and needs to be below 20 (currently 24).
What needs to be done to lower this?
Your comment 2:04pm, Friday 28th July 2006
Type - should be disconnects but doesn't reconnect.
Anyway, James Bailey tells me that this doesn't matter? Only support I have had so far against this ticket!!
************************************************************ [end of ticket comments]
Any help getting this resolved would be greatly appreciated. Kind of makes scheduling downloads a little useless if there is no connection and I can't re-establish it!!!
Grimbo
I have the same problem which (like you) has just started to happen a few days after I was dumped onto Tiscali LLU.
My post is here...
http://portal.plus.net/central/forums/viewtopic.php?t=46110
Please feel free to contribute to it.
Also same problem for a whole month of LLU now. I sync at 4M but get dial-up/isdn type speeds and have pretty bad packet loss causing disconnections and loss of sync. sometimes it will reconnect itself after a while and other time I have to reboot the router to get things going again. I lose sync between 1 and 10 times a day and disconnections without losing sync much more frequently still. But didnt you notice adsl has green status and there are no servicewide problems (only tiscaliwide ones it seems).
bigtim
maybe a dumb question but how do i find out if im on the tiscali thing
Grimbo
They sent me an email telling me it had happenned!
