Router help
Router help
basically i want to forward my port, so inorder to do that i have to go to the Router configuration screen. so the problem is that when ever i go to the Advance menu in router configuration screen it wount load up. Everything stays in the quick menu screen and it shows me the connection status. i have a Voyager 205 router.
i tried restarting my pc, connecting through USB, reseting router and restarting router and i am still unable to get to advance menu.
lol any ideasHuh?
Alecto
Router help
Looks like a common problem with that router according to this.
The answer seems to be the factory reset switch and persistence - Cry
Ziggur
Router help
I had this common problem.
My first solution was to follow the advice on this excellent page (scroll down to para 2) . That worked.
Then I realised that it was Proxomitron that was blocking access.
A simple modification to the filters solved that problem and now I can get to the Advanced pages by the normal route.
Router help
tried everything. it looks like routers short life coming to end. i had trouble connecting to net about 10 minutes ago.
Ziggur
Router help
I can now see that i missed off the vital URL in my previous post.
Here:
http://corz.org/comms/hardware/router/router.troubleshooter.htm
