Router Problems
Router Problems
Hi there!
Im wondering how to re-direct a port to my IP. I have this program called HLSW it pings servers for games, and one of the options is to recieve logs from a certain server.
This is what it says on the FAQ
"Router/Gateway Configuration:
You have to setup a port-redirection for port 7130 (UDP) from the Router/Gateway to the LAN-Ip-Adress where HLSW is running ! "
Anyhelp on how to do this would be greatly appreciated
Router is the GS8100
David
1 REPLY
Ianwild
Router Problems
Maybe you could try the ADSL Forum here, or the hardware discussion forum at www.adslguide.org. I have never come accross that router...
Regards,
