Rin trial
ForeverArsenal
Rin trial
Hi
Is there any news on when we can trial the new rin network yet please :?:
Fixes: 8
Rin trial
Go to here and view "Questions in the last 28 days". If there is a closed Service Notice that says
A modify order has now completed on this account to place the customer onto the new network.
your account is ready to try the new network.
Change your login in your router/modem to pinebox88@plusdsl2.net and away you go.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
ForeverArsenal
Rin trial
Hi elvin.
Thanks for that,just checked as you suggested and the above was done yesterday.
I've been waiting for +net email that they said they would send to activate Rin.
Many thanks,going to try now.
ForeverArsenal
Rin trial
elvin,have done above and rebooted router.
When I go connection settings in members centre ,click static IP it says,Current Status : You are now using a static IP address....is that correct :?:
on PAYG account.
Fixes: 8
Rin trial
Basically - no!
It is still a trial so they have crossed all the t's and dotted all the i's. RIN IP's are dynamic, but your old IP is still reserved for you if you choose to go back to the old network - so you have sort of got a static IP, but you are not using it.
Fixes: 8
Rin trial
Also, if you go to http://usertools.plus.net/@gateway it will tell you that you are not a Plusnet user!
ForeverArsenal
Rin trial
Basically - no!
Thanks again elvin,all a bit to much for my old head Sad
Just read a post lower down with similar question so
had semi-sussed it out.
Nice to know for sure tho.
again thanks for help.
The_10th
Rin trial
Thanks for the pointer about the RIN change notification. I looked to find my problems began after the 'change' took place at PN. :idea:
Rin trial
I have the "A modify order has now completed on this account to place the customer onto the new network".
Does everyone use the same login (pinebox88@plusdsl2.net)?
When are Plusnet going to write to people as they said they would in the original email?
Plusnet Staff
Plusnet Staff
Rin trial
The format of the username on the RIN network is username@plusdsl2.net for everyone. We're still in the process of placing the orders to enable everyone to be able to take part in the trial so it'll be a week or two before the next email is sent.
Fixes: 8
Rin trial
If you look back that message was in reply to a post by user pinebox88.
gm4jjj
Rin trial
Just a wee note to say I am currently trying the RIN and it is working very nicely for me. Seems faster at opening webpages - perhaps something to do with the DNS? - Certainly no complaints with it.
Rin trial
All PN will have done is added the option to use RIN to your account.
If you haven't changed over to RIN, there should be no difference.
lank111
Rin trial
can we use both accounts say, i log onto my @plusdsl.net at the mo,
log off, log on to the test account - @plusdsl2.net
and if i dont like, log back onto @plusdsl.net the same day?
i have static IP and my own hostname ( home.west-wire.co.uk not lank111.plus.com ), will this get affected?
James
Rin trial
You can use both accounts.
You will not have a static IP on the @plusdsl2.net login.
