Repeat event
Repeat event
Sorry if this is a really stupid question, but I want to set up an event so that it repeats every month and appears in the diary within organiser on the same date each month.
I set up an event on the 24/04/04 and wanted it to repeat on that date each month, however it is only showing on the 24th April and no other month. What have I done wrong?
The square with the 24 in it is shaded, what does that signify?
Thanks in anticipation.
csogilvie
Repeat event
Theres an "I want this event to repeat" checkbox when you create a new event... when you tick that and submit you can choose the repetition time on the next screen.
Repeat event
I see the option 'This event repeats' then I choose Monthly, what number do I put in if I want the event to run indefinately?
Thanks.
csogilvie
Repeat event
999 should do it (its 83 and a quarter years...)
