Regrades/Max DSL
Regrades/Max DSL
I am currently on the Premier £21.99 option, if I regrade to the £29.99 option, as my exchange is enabled for Max DSL, will I be automatically put on this when the regrade goes through? Also how long does the regrade usually take?
Cheers
1 REPLY
Midville
Regrades/Max DSL
No i dont think you would, because it is not classed as up to 4/8mb which are the first to get upgraded at the minute.
