Region Access Issue
Region Access Issue
(almost) Can't access any websites in China since last night.
ping www.sina.com.cn
Pinging antares.sina.com.cn [218.30.66.110] with 32 bytes of data:
Reply from 218.30.66.110: bytes=32 time=467ms TTL=50
Request timed out.
Request timed out.
Reply from 218.30.66.110: bytes=32 time=465ms TTL=50
Ping statistics for 218.30.66.110:
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Approximate round trip times in milli-seconds:
Minimum = 465ms, Maximum = 467ms, Average = 466ms
ping www.sohu.com
Pinging pagegrp2.a.sohu.com [61.135.150.76] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
ping www.qq.com
Pinging www.qq.com [61.172.240.46] with 32 bytes of data:
Reply from 61.172.240.46: bytes=32 time=461ms TTL=50
Request timed out.
Request timed out.
Reply from 61.172.240.46: bytes=32 time=463ms TTL=50
Ping statistics for 61.172.240.46:
Minimum = 461ms, Maximum = 463ms, Average = 462ms
thejudge
Region Access Issue
Region Access Issue
that's the reason!
i also found this news.
thanks and happy new year Smiley
Region Access Issue
It is usually helpful to post a full tracert where we/you can then tell where the problem is when you can't access a particular website. A ping only tells you if the final destination is reachable, not where the problem is.
