Referrals Question?
LiamM
Referrals Question?
If I refer someone to Plusnet PAYG Dialup access and then a few weeks/months down the line they upgrade to ADSL, will i get recognition for this or will they have to specify my username again?
Referrals Question?
Just get them to specify your login name when they register for ADSL and it should be sorted out.
Referrals Question?
When you upgrade you are not asked to specify who refered you.
However the original referal should still be in the system and you should get credited with the new account type.
At least this has worked for me in the past when my referals have upgraded Cheesy
Referrals Question?
I can confirm your referral of that user will remain in place and you will continue to benefit regardless of which account he might change to in the future (unless it was a PAYG one of course, we arent that generous Smiley )
Regards
Nick Dodds
LiamM
Referrals Question?
Thanks,
Glad I cleared that one up! Cheers!
