Referrals Problem - Web Portal
Over the past week there has been a problem with the referrals feedback when logging into on Member Centre in the portal area :? , this shows up the double amount when clearly the billing referrals credited to billing invoice is credit the amount shows half the amount Sad
Are you have the same problem.
ceridwen
Yep - basically it increases every month. i.e. the first month it is correct, then in doubles, trebles, quadruples etc.
The developers have been investigating this problem for at least the last four months... Not sure whether that says something about the developers or the complexity of the PN's systems.
Matthew
MysteryFCM
Bit of both I'd guess Wink
