Referals value
carpangler
Referals value
When I log into my account it says at the top I have had 9.02 referals ths month. Now I wish it was this as that would be good. It seems to have been wrong all month and hasn't been reset since last billing I guess as it seems to be about double the amount.
Mmmm - I might try to hold them to that. If F9 give this info then they should ensure it is correct, as misleading/wrong info, especially when it comes to billing is as much use as chocolate fireguard!
Has anyone else got this problem. I suppose I shoudl raise a ticket eh :roll:
Referals value
I'd recommend raising a ticket, although I believe a problem already exists on it (I believe it might be 32474) so it should be looked in to. Unfortunately, I think it's just a display problem.
ukbrown
Referals value
My referrals value show as £2.00 but I have only had £1.50 deducted this month
