Recent browsing speeds...
Hi, has anyone else been restricted recently due to high Peak time use, so much so that you can't even browse the web?
I had a message from PN to say they dont do this...but I thought I had seen quite a lot of people from different areas complaining of this....
Does it happen or was I just unlucky? Sad
Oh and my last 2 months peak downloads were both under 6GB...so hardly criminal amounts.
Fixes: 132
Hi
Check this thread Sudden & Dramatic Drop In Speed.
If you are really being throttled when you shouldn't then persever. If you reach the right person you will be listened to and things can get sorted Smiley
Regards
Forum Moderator and Customer
Thanks for the link...interesting.
They did reply to me just over 24hrs after I made me speed issue aware to them and all seems ok for now....I was still being restricted from previous month..some sort of error their end.
It does have me woried that if I do go over my limit again..they will restrict so badly using the net at home is painful.
Maybe I'm wrong, but is 6GB a month heavy?
Fixes: 132
Hi
What product are you on?
I think you have the answer in your post:
Regards
