Really Deleting SPAM
BoneMan
Quick suggestion for the current WebMail system. When we delete mail in the SPAM folder, could it really be deleted then and there rather than being moved to TRASH - from where we have to delete it again :? ? I understandthe logic of first delete = --> Trash and agree with it ... except for SPAM Wink . This would just make life easier and simpler.
Regards,
Ray
Plusnet Staff
Plusnet Staff
Bob was drawing up a list of things to do, I'll see if I can add it on the list. One thing about the spam in the spam folder is that it will get deleted after 30 days if you don't touch it, but will see if this can be added.
BoneMan
Thanks for the positive response.
Ah, didn't know that. So basically, if you trust the spam filter, you need never bother with the SPAM folder Wink .
That's good.
Regards,
Ray
