Random disconnections?
Hi, been noticing alot today my connection dying, its happening completely randomly probably 5 or 6 times today (annoying on xbox live), cant load any webpages either.
I restart my router and it comes back up, but im not sure if its a router problem or DSL dropout. Is anyone else experiencing the same thing?
Plusnet Staff
Plusnet Staff
Fixes: 159
When this happens does your modem/router lose sync with the exchange? The normal symptom of this is the DSL light will go off or start flashing.
 Chris Parr
 Plusnet Staff
i will check this next time it happens
it just dropped out for 5 minutes. No webpages would load and all other traffic stopped. I didnt restart router and it eventually started again - the sync light on the router remained contant?
