Random Disconnections
Hi all,
Is anyone getting random disconnections all the time. I've had it in the past couple of months where I'm online downloading or playing a game or even just on MSN. It happens every 15mins or so during peak time and every couple of hours during off-peak. I've updated my drivers, got new cables, borrowed my friends filters and its still happening.
Any suggestions Plusnet?
ye happened 2 times yesterday.
and has happened several times few months ago.
when ever i download
so fustrating. it happens at least 25 times a day for me. do i need to raise a ticket for this?
Yes, happening to me to :x
arr, me hearties it sounds like you may have done some of this but if tis a sync problem (flashing DSL light) you need to see:
http://usertools.plus.net/tutorial/id/10
http://usertools.plus.net/tutorial/id/13
madswitcher
an could ye be tellin us what type of modem ye have installed. Is it one of those pesky USB type?
If so ye could be having the 'ol USB power problem that plagues the Internet community.
a curse on the USB devil
aaahhhh haarrrr
Your link takes me here..................
Not Found
Unfortunately, the page you requested (/tutorial/id/13) was not found on this server
And i am using the Netgear DG 834 router.
do we get a discount on car insurance 1066?
try plugging the usb modem in a usb hub if u have one
madswitcher
aaaahhh Mr Soundsystem sirrr
the insurance depends on what type of 'ol tub ye have and the condition of yer motley crew.
For ye of a disconnecting disposition ye should try te USB powered hub trick to see if it solves the bedevilled power motherboard curse.
'Tis one also associated with a line upgrade as well since current pulled from ye mother's board is proportional to ye line speed and can cause ye mother's board to trip its softyware ffuse should ye current go past 500mA.
'tis a well known curse.
aaaah harrr
Ben_Brown
Hello there,
The links aren't quite right, here are the corrected ones:
http://usertools.plus.net/tutorials/id/10
http://usertools.plus.net/tutorials/id/13
yeah i have a USB modem. Alcatel 330. Wanadoo gave it to me when I first got broadband...and then I joined PlusNet and kept using that modem. You think I need a new modem? Because, i mean, I didnt have this problem with Wanadoo. Thanx for replies all!
As people have said, it may be that the higher speed is drawing more more from your USB connection.
For clarification, is it plugged into the motherboard or a powered hub? If it's the former and you dont fancy a new modem, I suggest a powered USB hub Smiley
It's plugged straight into my motherboard. I do have 2MB and I do download quite a lot...touching speeds of 220kb/s sometimes.
Does that mean that my modem is requiring more power than my motherboard can give? and therefore, the USB modem cuts off?
My router is mains powered and i have only been getting this problem for the last week or so, if its keeps happening i shall try my old usb modem and see if that helps.
hawarkarem - that could indeed be the problem, but there's no guarentees, someone else may offer an alternative solution Smiley
mark - wont be the same problm for you, and I'm afraid I don't know what it could be. But wait a little longer, there's lots of people that know lots more than me here Cheesy
