Raising a webmail problem ticket - How?
Saturn
How on earth do you raise a ticket these days to say the Webmail is broken - again?
Anyone know or is it just a ploy to stop more problems being uncovered?
Fixes: 69
We're aware that there are problems with Webmail:-
http://usertools.plus.net/status/archive/1152092949.htm
In future you can raise a question here:-
http://www.plus.net/wizard/index.html
Follow the wizard through as best fits your enquiry. If this results in a support page opening in a separate window then close it and you should see an option to contact the support centre.
Make sure you aren't blocking pop-ups and have Javascript enabled.
Regards,
Plusnet Products Team
Saturn
Thanks Bob, not that obvious really. Requires not taking the wording too literally. :?
I looked for a Service status message and it wasn't (still isn't listed). How did you access the message yourself?
Well the service status indicates an intermittent problem, I say it is offline/unavailable, retrying as suggested does not help.
SW.
3Mb FTTC
Re: Raising a webmail problem ticket - How?
Any why was the phone number removed from the bottom of each web page? It used to be so easy to contact support.
Fixes: 69
Should have been visible at 10.39.
Regards,
