Raising A Ticket
Raising A Ticket
Where can I raise a ticket - I'm completely lost?
I'm getting forwarded to numerous FAQ's - which I don't want, I want to contact a member of the support team about a connection problem.
Raising A Ticket
If you go into the support section, then open one of those nice helpers (the three dots moving along) minimise it, and wait a coupla seconds. The internet page you were on should move to include somthing like:
"Hasnt helped? Contact support...."
Hope thats right / helps!
Raising A Ticket
Did you resolve this.
Its one way to improve the call response time. Remove the option to raise a ticket. Come on plusnet you are taking the p###.
Raising A Ticket
"Hasn't helped" option has been removed from almost the entire help section.
Really upseting your customers isn't helping either Plusnet.
lingbob
Raising A Ticket
It's been replaced by: Alternatively, ask your question to the Support Team.
oliverb
Raising A Ticket
Well I don't have screenshots to prove it but during that broadband snafu last week I went to report it, and the only option I could find was the broadband fault checker which asked a few questions then reported that it was currently unavailable and redirected me back to the start.
Now I've since read of a "cheat" to get to raise a ticket manually but I consider this unreasonable.
lingbob
Raising A Ticket
If you'd have closed the window instead of answering the questions, you would then have had the option to "Ask a question". I know that sounds ridiculous but that's the way it works.
