Question response times
jennies
I have had to raise a question to PN support as my speed is almost unusable and has been for about a week - the all important question is how long do PN usually take to respond to these kind of support issues - 3 days or 3 months?
The_10th
What speeds have you been getting and what hardware do you use to connect to 't'internet?
jennies
BT Voyager wireless router
02-10-2006 19:18:44 127
01-10-2006 17:34:45 127.7
30-09-2006 10:25:18 126.8
30-09-2006 10:17:47 127.5
30-07-2006 15:29:15 938.6
30-07-2006 15:25:27 950.7
The_10th
So is when did this start and what attenutation/noise margins are displayed by the router? The figures on the right are what exactly excuse my ignorance? Shockedops:
good speed tester
jennies
Waaaayyyyy too technical for me. The figures I've just copied from my last few speed tests using the Plusnet bandwidth speed test, the far right figure is the speed I'm getting so 127 on my last test
As well as the Plusnet speed tester (which can be unreliable) try some from the ADSL Guide here and see what results you get from that.
I find it a bit more accurate than the Plusnet one.
It's worth just checking yuor exchange status also:-
http://usertools.plus.net/exchanges/
