Question for Plus Net admin...? Port Forwarding
I have a seperate thread running @ http://tinyurl.com/y983te on Port Forwarding
If I am using Broadband Plus , during peak hours, does Plus Net have a program running to detect forwaded ports on my router and stop connections being made to it ?
Fixes: 4
Re: Question for Plus Net admin...? Port Forwarding
Not AFAIK. Details of ports blocked on Plus here:
http://www.plus.net/support/security/port_blocking.shtml
I suspect this could be something to do with the php test script. It might be reacting to the traffic management of p2p traffic during peak hours. I've had a quick look for a copy of that script to see what it does, but can't find it. Sad
If you can download a copy of the script, send it over and I'll have a look
Moderators note by John (johnessex) Full quote of preceding post removed as per the Link:rules
Fixes: 4
Also, when did it stop working?
Hi there.
The short answer to this one is no. We do not monitor forwarded ports on your router.
The only ports we block are at our end and are detailed here
last weekend - I have no idea what is causing it - I forward the port, then suddenly its reported as being 'does not appear to be open' when I run a check (see http://tinyurl.com/y983te) I am wondering if there is something wrong with my router ....
Hi there.
thanks - that means I can rule this out.
