Question about the opt out of llu
I have a question about this opt out of llu. I was sent the letter on the 5 may 2006 which had the FAQ link, Did the FAQ have the opt out info in may?
As I what to go back to BT as the llu kcpts disconnecting and I had this for over two months, I don't what to pay.
If I have to pay I will just end my connection as this will cost me the same so I may as well use some else that is not llu. How long does it take for the tag to be removed so I can reconnect to the BT network.
Thanks for the help.
Mand
The FAQ did contain the opt-out link in May.
If you raise a ticket asking to be moved back and have had prolonged problems we will move you back without charge.
If you decide to cease the order will take 7 days to complete, and around 48 hours for the line to clear.
I have rasied a ticket and asked, the response was that I will be changed. What is the time for a prolonged problem?
Thanks for the info on the FAQ.
Mand
Please see my response to your ticket.
