Question about download usage
hi guys,i am on PLUS NET 2MB PREMIUM and i just want to make sure if it is unlimited.
regards
LiamM
To a certain extent yes.
You will be fine, unless you are using the connection in a way that is detrimental to the network, or the performance of other users' connections.
To do that, you've got to pretty much max out your connection 24/7.
ok ....fair enough....i want to give plus net a chance...its been an up and down thing so far////////////
LiamM
Are you having problems? Perhaps we can help?
at the moment,things are ok...im guessing that some evenings,the connection will be slower than unsual because its off peak...
suec45
You should have a pretty much clean 2mb connection, if you arent then contact PN through a ticket.
Otherwise they wont know that you are having problems.
With all the upgrades going on PN are very busy at the moment and so they have double the workload they have normally. Raise a ticket and tell them whats happening, there seems to be a few speed problems with some connections once the upgrade has gone through.
Mine however was totally smooth.
