Question For Ben Brown please.
Hi Ben,
Could you please tell me if it is possible , or how to go about getting a "Whoosh" test done on my line by Plusnet? I really would like to know what the line length is and S/N ratio etc is !!!! I would also like to know when the Basingstoke exchange is likely to upgrade my lion to 2Mb if possible , as the free upgrade was supposed to be started - originally April 2005 , then May , Then July , then ------- . I am on Home Surf 512K and joined Plusnet Nov 2002.
I have been getting some appalling speeds for some time now !!!!
Look forward to hearing from you .
PS:- if you want to know what DSLAM I am on then I 'll let you know if you answer this.
Kind Regards
Ian Garden
just raise a ticket asking for one to be done
A woosh test will not tell you your line length, only it's condition.
A request for a woosh test must go via contact us but unless you are reprting a problem, your request may be rejected as the woosh test is for diagnosing line problems.
Thank you guys for the reply. I will raise a ticket, although I don't know how far I will get with this.
Ian
shellsong
@gardeni
Have you looked at your stats using your own router-- see http://www.kitz.co.uk/adsl/frogstats.htm (I believe your router is there)
