Question About Speedtesters
Fixes: 132
Something I have noticed about speedtesters, particularly BBMax & Speedtest.net is that, most of the time, for the download test the dial jumps almost immediately to somewhere near the final result or higher and gradually reduces.
The Upload just gradually increases.
Just out of interest, does anyone have an explanation for this.
Yes, I am bored while I wait for a useable USENET Smiley
Regards
Forum Moderator and Customer
Most testers do a quick upload and download test for a few seconds to get a rough idea of speed you are running at which it then uses to 'calibrate' the tester and any graphing / dials.
This also allows it to determine the size of file to be used in the testing. If your on a 56K dialup, there is no point it using a 2MB file for testing as you would be there for ages, but if you are on a 4Mbs ADSL then a 2MB file probably is the correct size to give a more accurate reading.
As to why the upload test appears to gradually increase compared to the download, this is all down to the time taken to do the initial check. The slower the connection speed, the less accurate the initial test is so some testers may think the speed is slower than it actually is so starts at a lower figure.
Fixes: 132
Thanks for such a good insight Smiley
Regards
