Publish Destination
Publish Destination
I'm trying to use Frontpage XP for the 1st time. Could anyone tell me what to put as my 'Publish Destination' when I'm publishing the web to the fp site.
Much appreciated,
Robert
RE: Publish Destination
> Much appreciated,
> Robert
This needs to be fp.username.plus.com For further help on publishing with Frontpage please see http://portal.plus.net/supportpages.html?sRWYTaQ8I48%3D
Kind Regards,
Rob
| Robert Kelly.....................Unmetered & ADSL solutions
| Technical Support...................for Home & Business
| PlusNet Technologies Ltd...........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
I am publishing to the correct address then, but I get an error message when I do this:
'You cannot create a root web at "http://fp.zensible.plus.com". If there is a server at that location, you may create a subweb by specifying a location such as "http://fp.zensible.plus.com/myweb'
Do I need any other software as well as Frontpage XP to be able to publish my web site?
Thanks.
There should be no problems - we have many customers using FP XP successfully with 98 extensions (although I haven't used it).
Ensure you're not using XP-specific extensions as we currently only support FP98 extensions.
As I said before, you may be able to get help if you post this in the CGI forum or ask in our newsgroups.
Regards,
Mike
| Mike Grice....................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd.........@ http://www.plus.net
What!
I need extensions?!
Pray tell, what are those?
I assume it's nothing to do with making my hair longer!
I await you reply with bated breath..
