Problems with the RIN network?
wisty
I have been connected to the RIN network for about a week, with no problems. However this morning I had a problem connecting to News.Individual.NET.
Swapping back to the normal plusdsl realm allowed me to connect. It's fully repeatable. Switch back to the RIN (Plusdsl2) realm and again the news server times out.
Tracert on the RIN network gets as far as t2a7-ge7-0.de-fra.eu.bt.net then fails
Tracert on the normal realm gets all the way there (as expected)
Its not the DNS because both realms resolve to 130.133.1.4
I will raise a ticket, but anyone experiencing timeouts on the RIN network might like to try swapping back
wisty
Now seems fixed
Problem has been resolved. RIN network can now access News.Individual.NET
de-fra.eu.bt.net seems to have started talking to
ir-frankfurt1.g-win.dfn.de
Which is where the breakdown was occuring.
Plusnet Staff
Plusnet Staff
Sounds like a breakdown within BT's European peering, worth keeping a look out to see if there's any others as this is the sort of thing we should be able to feed back up the chain.
Is their a way to apply to go onto the RIN network or is a selected few trialist's?
It is currently only Broadband Pay As You Go users that are eligible for the RIN Trial.
Hi there.
The current trialists are all on PAYG accounts. Unfortunately your account change happened after the original batch was selected.
If / when we move the next batch you will be contacted and given the option to switch to RIN.
Unfortunately I have no time frame for when that might happen.
