Problems with DSL Connect
Hi
I would welcome comments from anyone using DSL Connect, re the connection problems.
Are you experiencing slow connection speeds, speeds as low as 19/20kbps if so please post a reply.
:?: :x
1 REPLY
jberry
Please do not post mutiple threads about the same subject, it just dilutes any discussion on the subject. If you want people to reply just reply to your other post - which will bump it to the top of the forums.
Regards,
