Problems with DNS 212.159.13.49 ?
churtonst31
Due to the lameness of my router I only have one DNS server configured (212.159.13.49). I've had a number of addresses fail to resolve today - but they work fine when I resend the request. Just wondering if this would indicate a simmering fault on the DNS?
Cheers,
Simon
All 4 DNS servers are running 100% for me (each line does a 200 lookup test)
___________________________________________________________________
212.159. 6. 10 | Min | Avg | Max |Std.Dev|Reliab%|
Cached Name | 0.014 | 0.019 | 0.035 | 0.004 | 100.0 |
Uncached Name | 0.016 | 0.102 | 0.252 | 0.055 | 100.0 |
DotCom Lookup | 0.018 | 0.047 | 0.174 | 0.046 | 100.0 |
212.159. 13. 50 | Min | Avg | Max |Std.Dev|Reliab%|
Cached Name | 0.014 | 0.019 | 0.037 | 0.004 | 100.0 |
Uncached Name | 0.016 | 0.102 | 0.229 | 0.054 | 100.0 |
DotCom Lookup | 0.019 | 0.049 | 0.176 | 0.048 | 100.0 |
212.159. 6. 9 | Min | Avg | Max |Std.Dev|Reliab%|
Cached Name | 0.014 | 0.020 | 0.037 | 0.005 | 100.0 |
Uncached Name | 0.017 | 0.117 | 0.244 | 0.055 | 100.0 |
DotCom Lookup | 0.023 | 0.080 | 0.303 | 0.068 | 100.0 |
212.159. 13. 49 | Min | Avg | Max |Std.Dev|Reliab%|
Cached Name | 0.014 | 0.020 | 0.036 | 0.005 | 100.0 |
Uncached Name | 0.017 | 0.118 | 0.271 | 0.057 | 100.0 |
DotCom Lookup | 0.021 | 0.085 | 0.301 | 0.072 | 100.0 |
UTC: 2005-09-08, from 22:47:07 to 22:48:27, for 01:19.672
You may need to look closer to home...
Is your system using your router for DNS lookups - i.e. is windows set to use your routers IP for DNS queries. If so manually set windows to use any of the above and see if it improves.
churtonst31
Thanks for that.
Is it OK to use the PN DNS addresses when I am connecting through a non-PN connection? I ask because I use wireless connections for my laptop and pda. I have my router at home set up as a DHCP server so that I can connect at home or on other wireless networks without the need to change any settings.
Yes, it will just be slower than using the corresponding DNS servers for the ISP you are currently connected to.
churtonst31
That's noted. Thanks very much.
