Problems using webcam
Hi
Can anybody tell me which network traffic priority msn / videocall / webcam is in. I just tried to use webcam via msn and its totally unusable, can not make out what is said and theres a 5 minute lag on video Cry . I have allowed all the necessary ports etc.
is there any plans to make this experience any better?
thanks
James
I'm looking into this now for you.
Robtheplod
are you by any chance connecting to another plusnet customer?
Liam
The issue of connecting between Plusnet customers on the same gateways being very slow has been resolved. It will, however, require a reboot on both sides.
Also remember that the person you connect to will only have a limited upload - so if you're also using the connection for things like P2P etc... that can max out the upload.
Robtheplod
i beg to differ on the resolved statement. I don't want to hijack this thread as it's for another problem, but still get cripling RDP connections when both ends using same gateway (both ends have been rebooted). i will get more info when the problem occurs next time and post...
Fixes: 8
Oh Yes?
http://portal.plus.net/central/forums/viewtopic.php?p=395018#395018
Why does the speed of their upload depend upon whether they are on the same or different gateway?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Liam
Thanks Jelv. I've made a note to speak to Networks when I'm back in the office... unless someone else beats me to it (no doubt Bob or James may do so!)
RE the upload speed - I wasn't talking about the gateway issue. I've seen issues in the past where the person who's webcam I am trying to view has Limewire or similar open and uploading at full line rate.
It's important to remember that with ADSL the upload is far lower than the download - and using webcam will rely on the remote participant not using it all up with other things.
Been away having my tea Smiley ,
This was actually a test run with a my next door neighbour who is on a much FASTER NTL 10MB connection. My voice / video uploads to him seem fine (a bit choppy, but I expect that during peak), its just my downloads, his voice (unusable) / video (5 min lag). Both of us were only using MSN and made sure that this WAS the only connection USED on our networks.
From what I can gather MSN / Video / Voice calls has not been usable for a least 1 year or more. Back to my original question...
* which network traffic priority msn / videocall / webcam is in
* is there any plans to make this experience any better
thanks
bumping this so I can get a answer to the above ...
I also noticed that at 15.55 and 00.05 MSN disconnects and reconnects due to the change over from peak to off peak and visa versa. Any plans to fix this?
thanks
Isn't it about time PN published a full table of what's classified as what? Oh wait, that would be too easy.
Plusnet Staff
Plusnet Staff
MSN traffic classified as a mix of gold and titanium with the file transfers in silver.
Not seen any other reports of MSN disconnecting at 15:55 and 0:05, the rule changes don't start until 16:00 so if it's disconnecting before this I'm not if it's down to peak to off peak changeover.
Plusnet Staff
Plusnet Staff
Should be publishing a list of games we have classified shortly, keep an eye out for a sticky in the gaming forum tomorrow.
