Problematic DNS Issues
craigbrass
Hello,
Over the past two weeks or so I have been experiancing what I think to be DNS issues. Suddenly I cannot go to any site at all. It just says server not found. 30-60 seconds later, connectivity comes back and all is fine. I thought this was at my end but looks like it isn't now. I was talking to "solstans" about somthing else. He is experiancing the EXACT same thing. Any ideas what this may be?
WXP Pro / Firefox 1.5 / DG834G v2
Best Regards,
Craig Brass
Plusnet Staff
Plusnet Staff
I saw solstans make a post earlier, but I think he deleted it while I was posting. The nameservers for the site he gave weren't responding which seemed to be the cause of the problem.
Which DNS servers are you using? I'd suggest specifying them in your network settings and see if that makes a difference.
The DNS servers are
212.159.6.9
212.159.6.10
212.159.13.49
212.159.13.50
craigbrass
I already have specified the latter two.
